A basic Cheat Sheet / Guide to config a Hypercore motor (similar to Superflux?) in VESCtool 6. This guide discusses motor values to be adjusted, it does not replace basic understanding of settings. This guide shows desktop VESC Tool, but it can be used for the APP version.
This is a written version of Dado’s Motor Config video with additional information, I recomend you watch it at least once. VESC 5.3 Hub Motor Configuration using the Wizard - YouTube
Always back up MTR and APP Config to maintain a base if you need to go back. If this is your first motor Config, it maybe helpful to load a working MTR Config first.
Set up Motor in UART (App Setting - General - UART- Write)
1. Welcome & Wizards - Set up Motor FOC
Load Default Parameters = No
EUC
Large Outrunner
Max Power Loss = 400W
Open Loop ERPD = 700
Sensorless ERPM = 2000
Motor Poles = 30
Motor Selection = Yes
Battery Type = LIIION 3_0_4_2
Battery Cells = Stock XR (64V) =15, TORque Pack (80V) = 19, CBCSO (84V)= 20
Battery Capacity = StockXR, TORque Pack, CBCSO or Custom?
Battery Settings = OK
Direct Drive = Checked
Wheel Diameter = 280 (for speed calculation)
Motor Poles = 30
Run Detection (Allow wheel to free spin)
Correct Results Range. Consider re-running Motor Wizard if you get number drastically different than below.
2. MOTOR SETTING - GENERAL (LEFT MENU):
GENERAL TAB:
Invert Motor Direction = Only if motor runs in reverse
CURRENT TAB:
Motor Current Max = 100A - 120A
Motor Current Max Brake = 100A -120A
Absolute Max Current = 180A+
Battery Current Max = 30A (you can use 50-60A for Molicel 2p packs, like TORque pack)
Battery Current Max Regen = -30A (you can use 50-60A for Molicel 2p packs, like TORque pack)
VOLTAGE TAB: (Dependent on Battery)
Battery Voltage Cutoff Start = 2.7V per Cell (54V for 20s battery)
Battery Voltage Cutoff End = 2.5V per Cell (50V for 20s battery)
TEMPERATURE TAB: (Activates Pushback for Overtemps))
Motor Temp Sensor Type = NTC10K@25C
Acceleration Temperature Descrease = 0% (VERY IMPORTANT!
MOSFET Temp Cutoff Start = 75C
MOSFET Temp Cutoff End = 80C
Motor Temp Cutoff Start = 80C
Motor Temp Cutoff End = 90C
3. MOTOR SETTINGS - FOC (LEFT MENU)
GENERAL TAB:(Crunch)
Motor Resistance (R) = 87 - 105
Observer Gain= ½ value (0.6 - 0.7)
**HALL SENSORS TAB:(Crunch) - we don’t use ENCODER **
Sensorless ERPMv = 2000
Hall Inerpolation ERPM = 200/250
FIELD WEAKENING TAB: (Personal - See Tune Cards)
Max Start= 30A
Duty Start= 50% (some people prefer 65% or more)
Ramp Time= 1000 (some people say 500 is better)
Q Axis= 2% (don’t touch!)
Motor “Crunch”
Follow this guide to troubleshoot. Reminder to make one change at a time. Motor crunch when braking hard
Common Causes in this Order:
- Observer gain (FOC-General) = HALF of wizard value
- Sensorless ERPM (FOC-Hall Sensors) = 2000
- Sensor Interpolation ERPM (FOC-Hall Sensors) = 200
- Zero Vector Frequency (FOC-Advanced) = Increase up to 30 max
- Motor Resistance (FOC-General) = 85 to 105
Backup and save Motor Config when successful.
*Comment if you see any errors or something needs to be added
