Before you create a new topic here, please make sure to check this topic. Here we will list all common issues including solutions or workarounds.
Issue: VESC Desktop App won’t connect via Bluetooth to my board
It’s a know issue. The only way to connect from Desktop app to your board is via TCP Bridge through your VESC App on your smartphone or tablet.
Solution: Follow the tutorial here: Connecting to PC VESC Tool with Bluetooth (How To) - FAQs & How-tos - pev.dev
Issue: When I try to backup my Float Package Config on VESC mobile app (via Float Cfg > ... > Save XML), I get error “Save failed” error
It’s a known issue, happens mostly on mobile devices.
Solution: Save the Float Package XML from Desktop app. See issue above how to connect to your Board from VESC Desktop App.
If you find any other known issues, just post them here or add it directly to this topic since it’s a Wiki!
