Getting Rid of the High Pitched Squeal
Coming from future motion firmware, the high pitched squeal can be off-putting to some. Luckily, tuning it out is super easy! Follow these steps:
  1. Motor Settings>FOC>Advanced
  2. Increase Zero Vector Frequency
Default is 20 kHz. Most people prefer it anywhere between 25-30 kHz.
WARNING Do not exceed 30 kHZ! At least two people have fried their VESC trying around 60-70. Be safe, don’t go above 30 kHz. Nico Aleman recommends not going lower than 14 kHz, although anything under 20 kHz is noticeably audible.
Nico Aleman has also said that “The sound is audible when holding brake current is active, which is triggered when you either start the board, write a config, or move the motor at all, and goes away once the motor has been still for about a second or two”.
See these other topics for more help with weird sounds:
Keywords: Squeal, beep, sound, high pitch, noise.
According to Shaman’s thread on esk8.news, it’s safe to go up to 35kHz.
I have heard many well known people in this community(Nico, Dado, and others) say to not exceed 30 kHz. I’m sure 5 kHz wouldn’t make a huge difference, but I feel being safer is better. Of course you have the right to crank it up as high as you’d like. I’m not tryna fry my controller ¯_(ツ)_/¯
Well Shaman designed it, so I would trust his word over anyone else’s. Not sure where the 30 kHz suggested limit came from.
The 30kHz suggestion is simply from observation/experimentation and leaving headroom for safety. I would rather suggest a max thats proven to be safe and has some wiggle room if someone decides to push it anyways, rather than suggest an actual max that isnt nearly as tested.
I trust Shaman’s word, and I myself even run 32kHz on a controller. It’s up to you where you put your trust and what you consider a risk. Im still gonna continue recommending 30kHz simply because i know some will try to push beyond thay anyways, so it leaves a safety margin.
On my x10 BTG XRV 30khz still pretty noisy, but 32khz is nice and quiet. I see that’s what you run, ever any issues? I’d love to leave it at 32 because it’s so niceeeee​:ear::+1: your thoughts/experience, along with anyone else, would be appreciated!
It should be fine realistically
Thanks Nico, been riding it for over a week at 32khz, no issues, nice and quiet. I respect you knowledge, opinion, and experience, so I appreciate the answer and will report if anything does rise from this but I think that to be doubtful.
My XRV is on 20s now and the noise is louder now, is that normal? Does voltages affect zvf? At the same settings that were quiet on OEM 15s, which was 32, is now loud on 20s. Seems to get quiet again in the high 30s but worried to go that high, seems as if under 40 might be safe. Any thoughts or experiences? Also 28 seems ok on 20s now but not nearly as quiet as 32 was on 15s. Maybe I’ll just have to deal with 28, I really only notice it at slow speeds and balancing standing still most.
Yea 39 is nice and quiet with my new 20s2p pack….just don’t know if I should leave it there….I want to….any thoughts? Thanks guys
Besides noise, what does Zero Vector Frequency affect when it comes to board performance or riding?
