Why I nosedived?
Hallo experts,
XRV/Hypercore, CBXR Batt, VESC FW 6.02, Float pack here.
Configured like this: loaded FW 6.02 and Motor.xml + App.xml + Float.xml received from Tony @ Floatwheel and strictly followed the GTV / XRV / PintV Power Kit Start Guide.
Did hundreds of miles without any issues. Just one strange thing: sessions from Floaty app detect Max controller speed more than doubled the Max GPS speed.
So, today, I decided to check the Wheel Diameter in motor setup.
To do this I’ve followed the VESC Tool helper here https://supzero.ch/vesc_config/ so I backup the config and Changed all the suggested Motor setup parameters of the tool:
Wizards/Setup Motors Load Default Parameters NO
Setup Motor/Usage Usage EUC or Balance
Override (Advanced) YES
Setup Motor/Motor Motor Large Outrunner
Max Power Loss 400
Open Loop ERPM 700
Sensorless ERPM 2000
Motor Poles 30
Motor Selection yes
Setup Motor/Battery Battery Type BATTERY_TYPE_LIION_3_0__4_2
Battery Cells Series 15
Battery Capacity 6.7
Advanced YES
Battery Current Max 20
Battery Current Max regen -16
Setup Motor/Setup Direct Drive
Gear Ratio 1
Wheel Diameter 279
Motor Poles 30
Detect all motors over CAN Bus NO
and run motor detection.
Went out for a test ride and after Few miles… BANG… WASTED at around 17 Mph. Fortunately I was fully protected so no boken bones… I restored the backup with the VESC app and went back home veeeery slowly…
What was wrong?
I attach everything from the recorded Floaty session; just change the extension from xml gpx json and csv.
1736091547345gpx.xml (57.6 KB)
1736091547345json.xml (569.5 KB)
1736091547345-logscsv.xml (236.6 KB)
Thank you in advance for your help experts!
Marco
Did you ever find out what was the reason?
I am completely new to VESC, however I see you set your battery current max. to 20 A. So I guess it maxed out the duty cycle when you reached 17 mph. Unfortunately I did not yet find out how to analyze your log.
This is probably your answer. Not enough amps permitted, too much demand.
