Importing Settings from Android Phone to Vesc Tool on PC
[edit: got it done]
I have my first vesc (XRV) set up. I’ve done all the configurations on my mobile Vesc tool app. I just downloaded Vesc tool on my pc.I’m trying to figure out how to transfer all the settings from my phone app to the desktop app.
You used TCP correct?
I just connected my vesc tool app on pc directly to my onewheel using Bluetooth instead of trying to transfer settings from my mobile.
Based on your question, we just added the steps to the docs: How to transfer VESC Settings from Mobile to Desktop
@Surfbear can you confirm if those steps work for you?
For clarification, if you want to use vesc tool on a different device you can install the app on a desktop, laptop or different mobile device and connect to your wheel to make (and save) any setting changes.
Connecting the vesc tool app on my desktop directly to my XRV via bluetooth was my solution to being able to use vesc tool on my pc. I did need to be able to connect to my wheel in order to have access to the settings.
Detailed steps are posted here:
