After seeing Surfdao’s video “the BMS dilemma” I wonder why almost everyone I see online goes for “charge only” when talking about FM BMS and pretty stock XR?
Not sure if anything has changed recently, I’ve read several times that if the BMS doesn’t talk to the FM controller, it shuts off within x minutes.
I guess if that were the case, Surfdado or anyone would NOT recommend it.
I just ordered a VESC controller, so I’ll be joining the club as soon as arrives.
One of my main reasons to go VESC is safety. Not Using safety as anti repair tactic, real safety!
In my case, a stock XR battery,I don’t see as a good idea to go blindly around with potentially damaged cells, Be unaware of having a fire hazard only to save myself from some cut off if the FM BMS worns me of a battery problem.
I plan to use OWIE to be monitoring via wifi the cells, and how they behave with the new controller and being pushed more than FM ever allowed them to. This board has his age, so does it’s battery. Sounds a good Idea to not be trusting it very much and be cautious, till it’s the moment I go fully VESC with a new BMS + higher voltage. or return to FM since would be reversible and I have a unicorn: 4209 that doesnt double down as a vibrator.
“I don’t know what I do’t know”
What are the things I’m not aware of that should make “discharge only” a better, safer option?
What would I be loosing if I keep the Stock FM BMS as discharge?
Will I lose much torque considering it is Stock 15s2p battery with 2k on it?
-Why charge+discharge is so unpopular?
Lastly, any schematics to what changes will I have to make to the UBOX switch if I end up using discharge BMS? Most things I’ve found up to now are RE charge only BMS.
