Whats everyone's avg wh/kms or wh/mile?
Hi there, just trying to see and compile battery and set ups vs range.
I used to have a CBXR on trail pro tire running 18psi (rider weight 205lbs geared up) and id avg 30-35kms or 18-21miles range.
Running lilfocr3.1, 18s2p p45b pack, superflux and trial pro at 18psi
Avg wh/km use is around 17wH/kms street (35kms) cruising and 18.6wH/kms trails (31kms)
*running Nicos fast flow tune with reduced atr uphill and rate p numbers for more loose feel
Thanks for participating
bump! mo data!!!
