I’m Developing my custom VESC hardware based on VESC 75V/300A Schematics, This is my first-time experience doing this.
I have assembled the board and burned the Firmware 75_300, and while performing the Initial test.
From the test I noticed the UNBALANCED_CURRENTS fault and HIGH_OFFSET_CURRENT_SENSOR fault code, the issue I have seen is that the current sensors are heating up.
The entire hardware is made of two boards, the first board holds the Mosfet, NTC temperature sensor, and Shunt Resistor, and the second board has the remaining hardware.
when I test the 2nd board it doesn’t have any issues, but when I connect with the first board there I have the issue the INA240A3d Current Amplifier ICs are heating up.
It’s the same schematics I have implemented, but I couldn’t figure out what the issue was and a way to rectify them. In the Image U5 is INA240A3D (Current Amplifier), and U18, U15 are Analog Switch.
Could someone help me with this?
