Starting off this is every ESC ever used in an Eboard
This is what you are here for. HV (I am defining at at least 10S) and Hopefully has an IMU, and if not better be dead cheap. VESC based ESC.
VESC HV / IMU
WIP
| Manufacturer | Name | Dims LxWxH (mm) | current_constant | current_peak | volt_range | connector_phase | connector_dc | sensor_support | motor_mode | input_controller | link_image | link_purchase | comments |
| Trampa | VESC_6+ | 75x70x18 | 80a | 150a | 6-60v | 4mm bullet | XT90 | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | http://www.trampaboards.com/vesc-6-plus-benjamin-vedder-electronic-speed-controller-p-26762.html | |||
| Trampa | VESC_6_75V | 300a | 450a | 14-75v | 4mm bullet *9 | XT90 * 3 | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | http://www.trampaboards.com/single-vesc-75v-300a-in-cnc-t6-silicone-sealed-aluminum-box--the-most-powerful-vedder-electronic-speed-controller-ever-p-26284.html | Nautical, Robotic, Scientific, Industrial, EV, Weapons | |||
| shaman | Little FOCer | 45x101x | 15V to 84V | Some New FOCers (84V VESC 6 based controllers) - Vendor Corner (SERIOUS) - esk8.news: DIY Electric Skateboard Forums | Some New FOCers (84V VESC 6 based controllers) - #4 by shaman - Vendor Corner (SERIOUS) - esk8.news: DIY Electric Skateboard Forums | ||||||||
| shaman | Cheap FOCer 2 | ||||||||||||
| shaman | Cheap FOCer 3 | ||||||||||||
| shaman | Tronic 250 | ||||||||||||
| shaman | Tronic 250R | ||||||||||||
| shaman | Tronic 750 | ||||||||||||
| shaman | Tronic 1000 | ||||||||||||
| shaman / SKP | SKP Solo | ||||||||||||
| Flipsky | Flipsky 75100 With Aluminum PCB | Flipsky 75100 With Aluminum PCB Based on VESC For Electric Skateboard – FLIPSKY | |||||||||||
| Spintend | Single Ubox 100V 100A motor controller based on VESC | Single Ubox 100V 100A motor controller based on VESC | Spintend.com | |||||||||||
| Spintend | 75V 100A single ESC single ubox based on VESC | https://spintend.com/collections/diy-balanced-boards-one-wheel/products/75v-100a-single-esc-single-ubox-based-on-vesc |
Want to add to this?
you need to edit this Spreadsheet and copy paste into this wiki,
leaving the “>!–td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}–>”
Thanks for helping!
