v6.05 is perfectly safe - BUT you need to be aware of a few quirks
PSA #1: Bug(s) in early VESC App v6.05 (use latest app!)
PSA #2: Nosedive bug in UBox v6.05 firmware (use latest app!)
PSA #3: Nosedive setting in all controllers!
Issue #1: Bug in old v6.05 iPhone App
Anyone with an old 2024 version of the v6.05 app - when connecting to your board make sure you explicitly press the Read button for Float Cfg / Refloat Cfg if you want to make changes.
The app has a high chance of silently failing when trying to read your package config - if you then make a change and hit write you’ll end up with ALL DEFAULTS in your package config.
Happens with any 6.0x firmware!!!
Just last night I tried setting “disable moving faults” during a group ride and got hit with an all-default Refloat Cfg… Luckily I had a Backup!!!
Issue #2: UBox Firmware Bug
All Spintend UBox users, careful when upgrading firmware!
Fix is Available, see Syler’s (devnull) comment below!
The Spintend UBox v6.05 firmware has a serious issue with the auto-shutdown behavior potentially shutting you down even while riding!!! Do your research before upgrading!
In case you didn’t know, Spintend Ubox is a VESC controller. If your board has a different controller (e.g. Floatwheel ADV200 or others) then you aren’t affected!
Issue #3: Nosedive Setting
On some boards the erpm readings will be way off when migrating from 6.02 to 6.05 firmware. They’ll read 10-50x lower than they should.
To fix: set Speed Tracker Position Source to “Corrected Position” which is the new default in v6.05!
How to downgrade to VESC 6.02 (or prevent update)
How to disable Auto-Update of VESC Android App:
- If you are on Android, go to the VESC Tool page in Play Store, hit the 3 dots on the top right and untick the “Enable auto-update” box
- If you are on iOS, should be similar in the App Store app (can anyone report?)
Download and install VESC App Download 6.02 APK manually
So meanwhile you can use the VESC App 6.02 APK shared by GRIMM which he shared Vescify Discord:
Mirror 1: https://cdn.discordapp.com/attachments/846794258093703228/1275581319430012968/VESC_Tool_1.apk
Mirror 2: https://drive.google.com/file/d/1XKQxJxTHnEjvMhMz7tiHRg3BE7icbBkj/view?usp=drivesdk
If you can’t access any of the files, try to open the message through this link and download it from there (you need to have joined Vescify Discord): Discord
