Ubox80 6.05 Firmware Auto-shutdown bug
Hi all!
I believe I encountered a bug in the new 6.05 firmware when using my Ubox80V with momentary button. Before the update I had the board set to power off after 30 minutes of inactivity, which worked great. After the update it seems that, with the same settings, the board powers off 30 minutes after power on, regardless if it was ridden. About 30 minutes into my ride (luckily I was going very slow at the time) the board powered off. I confirmed the issue by changing the setting to power off after 1 minute and standing on my board again. It powered off (while still engaged) 1 minute later. Be cautious while using the auto power off on the new update, it could have ended very badly for me!
