In case anyone else is wondering where the Tune Archive comes from and how to download it for your own offline comparisons…
For the moment, the float package gets the Tune Archive from the following URL.
Tune Archive (csv)
http://us-central1-mimetic-union-377520.cloudfunctions.net/float_package_tunes_via_http
You can use Google sheets and import the data using the function below
=IMPORTDATA("http://us-central1-mimetic-union-377520.cloudfunctions.net/float_package_tunes_via_http")
Or just download the csv and view it however you like.
| _name | Default Tune | Les Carroll - Underground Trail Tune | Les Carroll - Mission Clone | Mitch’s Chill Street Vibes | Nico - Fast Flow (10/1/23) | Nico - Street Growler (9/29/23) | Riley Johnson - Big Tire Float | Roadboarding (superflux) | VESCmann Allround | VESCmann BT Race (superflux) | VXwheel | JOKE TUNE: Loosey Goosey (Try With Caution) | Burnerz - Beast Mode (Cannoncore batch1) |
| double_float_version | |||||||||||||
| double_kp | 20 | 25 | 18 | 10 | 20 | 20 | 23 | 33 | 23 | 28 | 32 | 2 | 24 |
| double_kp2 | 0.6 | 0.8 | 0.7 | 1 | 0.8 | 0.8 | 0.7 | 0.4 | 0.3 | 0.6 | 0.6 | 0.2 | 0.9 |
| double_kp_brake | 1 | 1 | 0.4 | 1 | 1.2 | 1.2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| double_kp2_brake | 1 | 1 | 0.3 | 1 | 0.5 | 0.1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| double_ki | 0.005 | 0.005 | 0.03 | 0 | 0.005 | 0.005 | 0.005 | 0.005 | 0.02 | 0.06 | 0.05 | 0.001 | 0.025 |
| double_ki_limit | 30 | 30 | 30 | 30 | 30 | 30 | 40 | 30 | 30 | 30 | 30 | 30 | |
| double_kd | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| double_mahony_kp | 2 | 2 | 2 | 2.3 | 1.9 | 2 | 2 | 2 | 2 | 1.8 | 1.8 | 3 | 2 |
| double_booster_angle | 8 | 7 | 0 | 0 | 0 | ||||||||
| double_booster_ramp | 4 | 4 | 2 | 2 | 4 | ||||||||
| double_booster_current | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 40 | 10 | 10 | 40 | 0 | 0 |
| double_brkbooster_angle | 8 | 7 | 7 | 0 | |||||||||
| double_brkbooster_ramp | 4 | 4 | 8 | 4 | |||||||||
| double_brkbooster_current | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 28 | 10 | 10 | 0 | 0 | 0 |
| double_tiltback_constant | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1.5 |
| int_tiltback_constant_erpm | 500 | 500 | |||||||||||
| double_tiltback_variable | 0.1 | ||||||||||||
| double_tiltback_variable_max | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| int_tiltback_variable_erpm | 0 | ||||||||||||
| double_noseangling_speed | 5 | 5 | |||||||||||
| double_torquetilt_strength | 0 | 0 | 0 | 0.15 | 0.15 | 0.15 | 0.2 | 0.1 | 0.1 | 0.1 | 0 | 0 | 0.09 |
| double_torquetilt_strength_regen | 0 | 0 | 0 | 0.15 | 0 | 0.15 | 0.2 | 0.1 | 0.02 | 0.05 | 0 | 0 | 0.09 |
| double_torquetilt_start_current | 15 | 5 | 20 | 20 | 15 | 15 | 20 | 20 | 15 | ||||
| double_torquetilt_angle_limit | 8 | 8 | 8 | 8 | 8 | 8 | 5 | 5 | 7.5 | ||||
| double_torquetilt_on_speed | 5 | 5 | 5 | 3 | 5 | 5 | 5 | 5 | 5 | ||||
| double_torquetilt_off_speed | 3 | 3 | 5 | 8 | 3 | 4 | 3 | 3 | 3 | ||||
| double_turntilt_strength | 6 | 0 | 0 | 0 | 3 | 2 | 0 | 6 | 4 | 4 | 0 | 0 | 6 |
| double_turntilt_angle_limit | 3 | 3 | 3 | 3 | 3 | 2 | 2 | 3 | |||||
| double_turntilt_start_angle | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | |||||
| int_turntilt_start_erpm | 1000 | 100 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | |||||
| double_turntilt_speed | 5 | 5 | 5 | 5 | 5 | 3 | 3 | 5 | |||||
| int_turntilt_erpm_boost | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | |||||
| int_turntilt_erpm_boost_end | 5000 | 10000 | 5000 | 5000 | 6000 | 5000 | 5000 | 5000 | |||||
| int_turntilt_yaw_aggregate | 90 | 90 | 90 | 90 | 90 | 90 | 90 | ||||||
| double_atr_strength_up | 1 | 1.5 | 0.5 | 0 | 0.6 | 0.5 | 0.6 | 1.8 | 0.7 | 0.7 | 0 | 0 | 1 |
| double_atr_strength_down | 1 | 0.3 | 0.2 | 0 | 0.4 | 0.4 | 0.5 | 1.8 | 0.7 | 0.7 | 0.8 | 0 | 1 |
| double_atr_torque_offset | |||||||||||||
| double_atr_threshold_up | 0.5 | 0.5 | 0.5 | 0.5 | 1 | 0.5 | 0.5 | 1.5 | 2 | 0.5 | 0.5 | ||
| double_atr_threshold_down | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 1 | 0.5 | 0.5 | ||
| double_atr_speed_boost | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | ||
| double_atr_angle_limit | 8 | 6 | 6 | 8 | 8 | 8 | 6 | 5 | 6 | 8 | 8 | ||
| double_atr_on_speed | 4 | 8 | 8 | 5 | 5 | 4 | 4.5 | 5 | 10 | 4 | 4 | ||
| double_atr_off_speed | 3 | 6 | 6 | 3 | 3 | 5 | 3.5 | 3 | 7 | 3 | 2 | ||
| double_atr_response_boost | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1 | 1 | 1.5 | 1.5 | ||
| double_atr_transition_boost | 3 | 4 | 4 | 3 | 3 | 2.5 | 2.5 | 1 | 1 | 2.5 | 3 | ||
| double_atr_filter | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | ||
| double_atr_amps_accel_ratio | 9 | 8 | 8 | 8 | 8 | 8 | 28 | 12 | 18 | 11 | 9 | ||
| double_atr_amps_decel_ratio | 8 | 7 | 7 | 7 | 7 | 7 | 22 | 12 | 18 | 15 | 8 | ||
| double_braketilt_strength | 0 | 7 | 7 | 0 | 4 | 0 | 0 | 7 | 0 | 0 | 0 | 0 | 0 |
