Hi guys, I have a really weird problem with my freshly built VESC 20s XR Onewheel it has less than 100 miles on it, it runs on Tronic 250R controller, it was working fine from day one, and I didn’t change any settings before the issue pops, #1 simple stop doesn’t work anymore, #2 now at 10mph the push-back kicks in. I just did a new setup from scratch, but that didn’t help, also I reflashed the firmware on Tronic 250R and did the setup again, but the pushback at 10 mph is still there.
Also, on my other VESC XR which has a Little Focer 3.1 controller, I tried to activate a simple stop but now it doesn’t work either, and I know for sure that on the 6.2 was working fine before upgrading. Does anyone else have the same problem and know how to fix it?
most likely high voltage pushback - in the Specs tab of the package config you need to manually set the voltage thresholds for your pack. Search “battery voltage” here for some guidance.
