Current warnings or issues
2024-07-23T22:00:00Z
Official Setup video - risk of nosedive!
MAJOR WARNING to those who followed the Thor300 setup video and has the fungi battery
MAJOR WARNING to those who followed the Thor300 setup video and has the fungi battery. I noticed they incorrectly stated the battery voltage cutoff start at 65. It’s supposed to be 54 and the Voltage cutoff end at 60 which should be 50. Also they left the amp hours to 6.0 which it should be 5.6 “No you don’t want your board to ever go that low which would be 2.5v per cell but it’s supposed to be a last ditch effort to stop a fire during VOLTAGE SAG” With the fungi settings they have your board will nosedive on you before you hit 12% battery left under normal use. Also you need to set your low voltage tilt back to 60v and heed that warning.
The current setup video with Fungineers will have you nosediving. I repeat the setup video will have you nosediving. Consider yourself warned.
Source: Facebook post
