I have trouble getting superflux running - It spins only on the current loop. Makes weird noises when I trying to spin it to some RPM. Sounds ok while motor detection.
Adding superflux motor config - for me at least default wizard push incorrect motor poles no. If you are not reading the config first from VESC - even though you write there 30. Always read before write!
