Superflux HT - Best Field Weakening settings
Hello guys
I would like to get the most out of my SF HT motor without pushing it to the point of breaking something or falling.
I currently have my settings at 30A current max and 60% Duty start.
I’ve noticed that some people have theirs higher, hoping someone can give me a sweet spot where I can safely get the most topspeed.
Am running an 19s2p 50s battery pack
Grain of salt, but if I was running that setup personally, I’d go with 40A FW Current, 60% Duty Start, and 500ms. I go 45A FW on my racing setup with a 19s P42A battery, but the 50s has a lower continuous discharge rate, so I’d personally go a bit easier on it. Again, grain of salt, not a specifically informed suggestion, just what I would go with based on my own knowledge and intuition.
Thanks Nico, appreciate it
I’m not on a SF, but a HC and I’ve been running 40-45a, 75& 300… holy crap my board is so fast now. Only running it for testing then at Ohio underground finals this weekend. Not sure how safe it is but I wanna say hannes said I could go higher. Forgot whether you can run higher or lower w sf
