I’m trying to create a tune where haptic buz is set off at a specified breaking rate. My thought behind it is when I’m commuting I sometimes come up on large groups taking up the bike path and I would like to hit the breaks and the haptic buz triggers. I think this noise will be loud enough to notify groups I’m approaching. Any tips or thoughts on how to complete this? I want it to be per tune so I’m not having to listen to the noise while riding trails through the woods.
This is a really specific implementation, and would require implementing yourself in the actual code of Float / Refloat, which is a huge rabbit hole if you haven’t done that kind of work before. It’s not something anyone could easily walk you through, and unfortunately its specific and niche enough of a use case that I don’t think you’d have much luck finding someone to do it for you, outside of potentially commissioning someone to do it. But then you would be screwed out of any future updates as well
Ahh thanks for the information. I’ve gone down the rabbit hole a couple of times already. I’ll probably avoid it if I would have to reimplement the code for future updates.
