Pre-built VESC Boards - What Are My Options?
If you are looking for a pre-assembled board, albeit are not many options but they still exist. Downside is either a longer waiting time, hurdles with payment systems and availability issues.
Floatwheel: A Pre-built Option
For those seeking a pre-built VESC board, Floatwheel is a great option. Floatwheel offers boards with impressive specifications, and the assembly process is straightforward, involving primarily attaching the wheel to the main frame.
Downside is that only Crypto payment is possible due to legal issues by a certain FM company. Also shipping takes a few weeks.
Prewired Enclosure Drop In Kits
Some vendors started selling fully assembled Drop Kits which don’t require opening your enclosures at all. Instead you swap them out with already prewired and preassembled VESC controller and battery+BMS.
Downside is that those can be really pricey since they are not mass produced and rather assembled by hand. Yet this a great way to support local board shops. Also you can either keep the stock parts or resell them.
VESC Configuration: Essential Knowledge
Even with a pre-built option like Floatwheel, understanding VESC configuration is crucial. While the initial setup might seem simple, it’s easy to make mistakes that render the board unrideable.
Configuring a VESC board offers a high degree of customisation, but there are no safety nets to prevent dangerous settings. Third-party apps can assist with the process, but a learning curve is still involved.
Finding Assembly Assistance
If you’re not confident in your DIY abilities or lack VESC configuration knowledge, some Onewheel service shops offer VESC board assembly.
You can check out our Verified Vendors and Builders section
However, it’s important to note that this is a niche service, and finding experienced builders can be challenging. When working with a builder, patience and understanding are key, as they might be learning as they build your board. Regardless of who assembles the board, you’ll still need to learn how to configure it to avoid potential issues.
