This is the first edition of The VESC controller spreadsheet. For the moment, it’s incomplete and needs to be updated. Credit goes to Nickleman from the Vescify discord server.
This is epic! Can you share the markdown or raw file of this comparison table? Then we can embed it here natively.
Here’s a markdown version. I didn’t edit the original post yet, as I’m not sure the meaning behind the color coding and if it’s important to preserve or not.
| Ubox 80 | Ubox100 | lilFOCer 3.1 | Tronic 250r | Thor 300 | Raiden 7-HV | |
| Price | $160 | $140 | $300 | $250 | $300 | $179 |
| Max Current (Not ABS) | 150A | 100A | 250A | 250A | 300A | 120A |
| Max Voltage | 75.6V (20s) | 84V (20s) | 84V (20s) | 100.8V (24s) | 84V (20s) | 92.4V (22s) |
| Connectivity | (2 serial ports) External serial Bluetooth | (2 serial ports) External serial Bluetooth | (1 serial port) Internal serial Bluetooth (iPhone connection issues) | (1 serial port) Internal serial Bluetooth (iPhone connection issues) | (1 serial port) VESC express (only supported by VESC Tool app) | (1 serial port) External serial Bluetooth |
| Internal Footpad Resistor | No | No | Yes | Yes | Yes | No |
| LED Compatibility | 12v supply | 12v supply | None | None | 12v supply + controls | None |
| Momentary vs Latching Power Switch | Both | Both | Latching | Latching | Momentary | Latching |
| OEM w/ Heatsink | Yes | Yes | No | No | Yes | Yes |
I used a google sheet to make the imagine
Well we can go either way:
Option A) Enrich the Google Sheet and add more infos about each controller
Option B) Use the Markdown table here in pev.dev natively
What’s more user friendly in your eyes?
I think markdown might sound like a good idea. I just need to learn how to use markdown
