Nose lifting On Ado Pro
No matter what settings I change I feel the noise lifting more degrees then I would like and I’m starting to think I may need to re calibrate
FC_Shape_MISSION.xml (1.8 KB)
Any input would be appreciated =D
?xml version=“1.0” encoding=“UTF-8”?
MISSION
FF2D55FF
16.00000
0.01000
0.60000
<ki_limit>30.00000</ki_limit>
<mahony_kp>2.00000</mahony_kp>
<booster_ramp>4.00000</booster_ramp>
<booster_angle>8.00000</booster_angle>
<booster_current>0.00000</booster_current>
<brkbooster_ramp>4.00000</brkbooster_ramp>
<brkbooster_angle>8.00000</brkbooster_angle>
<brkbooster_current>0.00000</brkbooster_current>
<torquetilt_strength>0.03000</torquetilt_strength>
<torquetilt_strength_regen>0.03000</torquetilt_strength_regen>
<torquetilt_angle_limit>7.50000</torquetilt_angle_limit>
<torquetilt_start_current>15.00000</torquetilt_start_current>
<torquetilt_on_speed>5.00000</torquetilt_on_speed>
<torquetilt_off_speed>3.00000</torquetilt_off_speed>
<turntilt_angle_limit>3.00000</turntilt_angle_limit>
<turntilt_strength>5.00000</turntilt_strength>
<turntilt_start_erpm>1000.00000</turntilt_start_erpm>
<atr_strength_up>0.80000</atr_strength_up>
<atr_strength_down>0.80000</atr_strength_down>
<atr_threshold_up>0.50000</atr_threshold_up>
<atr_threshold_down>0.50000</atr_threshold_down>
<atr_speed_boost>0.30000</atr_speed_boost>
<atr_angle_limit>8.00000</atr_angle_limit>
<atr_on_speed>4.00000</atr_on_speed>
<atr_off_speed>2.00000</atr_off_speed>
<atr_response_boost>1.50000</atr_response_boost>
<atr_transition_boost>3.00000</atr_transition_boost>
<atr_amps_accel_ratio>9.00000</atr_amps_accel_ratio>
<atr_amps_decel_ratio>8.00000</atr_amps_decel_ratio>
<braketilt_strength>0.00000</braketilt_strength>
<braketilt_lingering>2.00000</braketilt_lingering>
<noseangling_include>0</noseangling_include>
I assume you don’t have constant tiltback or Variable tiltback enabled in Tune Modifiers? You didnt include them in the config file. If they are disabled, then it’s likely related to IMU calibration, possibly a really bad accelerometer calibration if it starts at level when you engage but lifts when you actually ride
I resolved this one with IMMU and accelerometer calibrations
