Newly built lil foccer v4 motor cutting out when breaking
after finishing my build, everything is running fine but when I break it says overcharge fault, and the motor cuts in and out this is only when it happens
When I break I think it happens when it goes over 95 volts I tried to increase the input, but it says it can’t go any higher I am also have trouble charging the light stays green even when it is plugged in
Stock XR motor
Stock charger
Float package
Stock XR battery pack
Maxgo charge only bms
