New installed GTV won’t turn off
I installed my GTV kit a few days ago and it won’t turn off by holding the power button. If I try for 30-60 minutes I can sometimes get it to turn off.
I tried going to APP CFG->General and setting shutdown mode to “Off After 10s” and Write but it didn’t work.
I opened up my controller and reseated the power button cable but it didn’t fix the problem. It doesn’t look damaged at all and the port on the controller looks solidly in place. The cable clicks into place very easily.
Since it turns on after one press every time, I don’t think the issue is with the button. Could the issue be with software?
I tried to reach out to Tony but he doesn’t respond. This is such a frustrating issue.
Had this on a pintV kit. Fixed with older fw 6.02 vs 6.05 iirc.
Confused me as it should have no effect… Open source can be a pain
