Loop hertz settings
When I open the float control app it gives me a warning that my float config> specs> loop hertz is set to 832 MHZ but my App cfg>IMU is set to 800 MHZ and they should be the same.
But which one is correct?
We can’t answer that without knowing your controller. If it’s an XRV, both should be 800Hz
Ahh ok Thanks mate, yes its an XRV. I had changed them both to 800mhz so will keep it at that.
