I recently the Little FOCer V3.1 but I cannot seem to simply run the motor without making a horrible groaning noise. Trying to run the motor right after motor calibration with the VESC tool yields a very apparent noise.
Please see video here: https://photos.app.goo.gl/nY6GdTuxrFd9VmhRA
I already tried changing the zero vector frequency up to 30kHz but the motor still makes the noises.
I could not hear any unusual motor sounds in the video but your L and Lq-Ld are very high for what a hypercore motor should detect at.
It has been hard to track down this issue because it is very intermittent. Eventually we were able to isolate the cause in a way that we are confident it happens when high voltages are applied without a power ramp up. So you are more likely to experience it on high voltage packs like 19s and 20s than a 14s or 15s. You can test this by specifying the motor detection to use less amps… IIRC, i think it defaults to 50amps but this is configurable in the wizard
We are working to test a fix that we can ship to you once we have tested it and its ready. So send an email to support@makerspev.com and we will get the fix to you as soon as its ready.
For now, i am assuming you are running vesc6.0 or 6.2, if you roll back to 5.3 firmware for the time being, it will probably not be a noticeable anymore. This is why we have continued to ship all of our little focers with dado’s v6 firmware and have not yet adopted 6.x. This is a hardware related issue but some software versions deal with it a lot better. We never noticed a problem until we started using 6+ firmware because 5.3 just behaved better [in relation to this issue.]
Note, that we were still shipping focers with v5.3 because originally we believed it to be a software related issue. But once we confirmed the problem is hardware related, i have set our inventory to zero while we validate the fix, then flash and fix all existing inventory before resuming shipping. We apologize for the delay. We will announce a voluntary recall where we ship a fix to anyone that is having this issue when upgrading to vesc 6
did not hear anything out of the ordinary. However if you don’t like the result, as brian said rolling back to 5.3 could help. Alternatively you could try motor config > FOC > Advanced > observer type = ortega original. on v6 firmware this default is changed to mxlemming lambda comp (iirc), hence rolling back to old firmware.
I already sent an email to support@makerspev.com but have not received a response back. Also I was running V5.03 on the Little FOCer because I had the same issue on V6.0
