I’ve been searching, but havent found much information, let alone a guide to follow. I do most of my riding at night, but after converting my XR over to VESC, I’m not able to use the exisitng LEDs…at least that is what I believe. Anyone have a guide or willing to provide a plan? I’ve been stalking the AVASpark’s site at the recommendation of Indy Speed Control, but do not know what I should purchase.
I have a Little FOCer v4, and an 84v pack. I would love some RGBW lights, but night time visibility (for me and “them”) is my priority. The rear box is the factory XR battery box. The front box is the standard Makers PEV 3D printed control box without a LED window. Anyone have a STL file of a remixed control box with a sealed LED window, or know where I can purchase one made with something better then PLA?
[UPDATED]
See my comments at the bottom of LED Light Bar or other Lights Advice for how to add LEDs to a FOCer v3 or other controller that lacks sufficient power output:
Thanks for the feedback. With the Little FOCer v4, it says it can provide 5V @ 2A to accessories, do you think that will be enough? Also the V4 FOCer has a dedicated smart LED 3 pin connector. There doesnt seem to be much information out there for LED setups and the LFr v4. I guess I should just start buy some off of Amazon and see what works.
It was really frustrating trying to learn how to add LEDs and I updated the post you’re replying to because apparently I can’t discern a 4 from a 3…
For a Little FOCer v4, you need some 5V SK6812 LEDs, and there are lots of options to choose from.
You can get these 5V SK6812 LED strips on Amazon.com
or these 5V LED bars from AvaSpark, among others.
Unfortunately, I haven’t any direct experience with a LFOC v4 which only has 1 LED output and have instead used controllers like the Thor300 that have multiple LED outputs. That said, my understanding is that LEDs can be wired in series. The FOCer v4 has LED, 5V and GND.
The AvaSpark LEDs have 4 pins: RGB, 5V, GND on one end and RGBOUT, 5V, GND on the other end. The controller is wired to the front LED as follows:
LED → RGB, 5V → 5V, GND → GND
The front LED is then wired to the rear LED as follows:
RGBOUT → RGB, 5V → 5V, GND → GND
You may need the AvaSpark LED data signal booster if your rear LEDs flicker (mine did).
After the wiring is in place, you need to go into VESC Tool → Refloat Config → Setup and enter the correct specifications (I’ll check this when I get home and grab some screenshots).
I know that’s not everything, but I hope it helps!
I’m just getting into my FOCer v4 build and trying to sort out this LED situation. Any products that are plug n play for front AND rear LED strips? Seems like there may be some soldering required to do it properly with only 1 LED output on the controller.
Thanks for the reply. I saw this in the previous comment, but does this allow for individual control of each light bar? To me this sounds like both front and rear light bars would be mirrored at all times (instead of being individually controlled). Having said that, I have no idea what I’m talking about.
I can’t say for certain because all of my setups have separate plugs for each LED bar, but I believe the RGB wire sends a data signal through all of the LEDs, which are treated like one long strip. You just set the strip length in Refloat Config → Specs to tell the VESC where one LED bar ends and another bar starts. The example below is a front bar with 20 individual LEDs and a rear bar with 18 LEDs.
Actually the LFOC V4 is the same as the Thor. Thor also has only 1 LED data pin. The “ports” however are daisychained together so the user doesn’t have to daisy chain the LED strips externally. Using the LFOC v4, you will have to daisychain the strips together. Aka take the LED Data Pin from the LFOC into the first strip (headlight), then out of the first strip, then into the 2nd strip (taillight). The Refloat cfg LED settings under Specs assumes 3 strips are used - Status, Front, and Rear. You can disable any of them by setting their length to “0”. If there is no status bar, you should set its length to “0”. Then configure the front and rear lengths, and change between RGB and GRB color ordering depending on which LED strips you use (Amazon’s SK6812RGBW for example or Avaspark 5V RGB). I find the LFOC is actually easier to wrap my head around than the Thor using internal daisy chaining and incorrect pinout on their diagrams
