Issue with XRV and WTF rails configuration
I’m not sure I have this correct, sorry if this is the wrong place. I’ve done three installs of the XRV. One of the ones, I took out of WTF’s and put in a different frame. I then Went over all the values that were said to be important, and then watched the long and boring setup video, and made sure those were correct. It no longer does Magic Flywheel. This makes me think there is a bigger problem.
Is there a place where you could just check your values to make sure they are good(FM stock XR Battery, XR stock wheel/motor, Burris tire)XRV from Tony.
I’m selling this board so don’t really want to ride it. Thanks for all the people here’s tireless thankless work.
aoxo
I took the liberty and converted your post into a new topic :slight_smile:
