Hi all,
I’m trying to tune a motor for use with a propeller (currently running with no load) with VESC on a Little FOCer v4. When I run the motor with 8% duty cycle, it will show 1.5-1.9 amps. Raising the duty cycle will make the current drop until it goes negative at 12% duty. The motor sounds like it’s running rough, so I don’t think it’s tuned correctly.
The other issue I noticed is that when doing the RL measurement with I=15A, I’ll sometimes have measurements that reach 18 amps, but some measurements cannot even reach 2 amps. In screenshot below, three RL detections were low current (less than 2 amps), with one high current that reached 18 amps.
In another test I did, three measurements reached 18 amps, while one only reached about 5 amps.
controller/motor: Little FOCer v4
firmware version: VESC 6.05
package version (and name): None
configuration details: XCELL Turbine V2 6565
Test setup is a 60V 16A bench power supply connected up to a 15S bank of 45F supercaps to simulate a pack, with a 45uF film cap in parallel.
Edit: Tried a second motor and motor controller, but I get the same the result. Also noticed that if I run with duty cycle=20% then switch to duty cycle=10%, the motor will rapidly increase in RPM, and the duty cycle will shoot past 50% despite not being commanded to do so.
Thanks,
Grant
