Imu save slot on refloat
Is there a plan to put save slots for the Imu on refloat like float has? Had to switch a couple things on my board and was a pain having to keep installing one or the other.
there’s no plans and there should be no need for that. Why have more than one IMU config? Do you swap rails frequently?
In all other situations you should use Constant or Variable Tiltback in the Tune Modifiers Tab. Those do get saved
