If you have the following issues, you might need an Accelerometer Calibration:
- Nose drop issues on curbs
- Nose goes up down after tight U-turns
Required:
- Your Board, d’oh
- A free hand to move the board around
- VESC Tool 6.2 (latest version)
- VESC Firmware on board (no need to update to latest version, but should be 6.x)
- A working configuration, IMU should already be calibrated, i.e. if you slowly ride forward and backward the board should be equally level
Steps for Accelerometer Calibration:
Follow this video by @surfdado
Do not forget the “Backup Config” part to save your current configuration (1:40 in the Video)
