How do you increase the speed for a 48 volt scooter? in the software
You can change the wheel diameter measurment in your schooters’ firmware to artificially increase the speed. However, this will trick your board into thinking it’s going faster, when in reality it isn’t.
The only way to increase speed is with field weakening, but software can only do so much to increase your speed.
If you’re using VESC tool, you would need to go to Motor → Additional Info, then Wheel Diameter should be there
