GTV kit Rear Led Bar, Red lights do not work
New GTV install, Rear light bar red lights not working. They do go white when switching directions.
Maybe defective light strip?
Do both colors work on the front LED PCB? If so, you can swap that one to the rear (they’re the same) and test again.
If the same symptoms occur, your issue may lie with the LCM.
I did swap them so at least now I have a red light in the rear. Not too much need for the front to be red ever as I do not ride goofy. I would like to have it working properly but this works for now. How to get ahold of Tony? Do you know by chance?
Yep. He’s got a contact page where you can either fill out the form or copy his email address at the top for a direct email.
I hope this helps!
