Hey all I have a GTV installed in board with a stock battery, standard WTF rails and an n48 MTE hub.
I had been riding the stock GTV configuration until today when I just ran through Dado’s setup guide here: https://www.youtube.com/watch?v=xaKGDummXeE
Can I the community’s double check on these settings? Also if there are other settings I should double check for my setup of board/hub let me know.
Battery capacity: 18s, 5Ah
FOC-> General Motor Inductance Difference: 64.74 uH
FOC-> Field weakening Current Max: 30A
Field Weakening Duty Start: 65%
MTPA: Disabled
IMU: no settings changed since I followed the initial GTV Power Kit Start guide.
Refloat Specs:
High Voltage Threshold: 77.4V
Low Voltage Threshold: 54.0V
