FM Onewheel GT control board MosFets Shorted
FM Onewheel GT control board MosFets - Mates GT would only flash a quick single Green and then a row of white AND then OFF. You could also hear some clicking - typical of a short or breakover.
Q1, Q3 and Q5 all had shorts ? Snipped the legs and the unit now powers up and appears to behave - yet no Motor connected - as expected.
Have new 103RONS on order - However was interested to know of any tricks to unsolder the existing ones. They have a solid drain pad (heat dissipation) and will need a good amount of heat to desolder.
If anyone have been down that path - I would love any tips / tricks that you may have discovered.
While I have my fingers crossed - I am also aware they could have been a Motor issue that has caused these 3 MosFets to fail.
https://alltransistors.com/mosfet/transistor.php?transistor=63186
All mosfets replaced and found a simple method - no hot air gun = Just a big Soldering Iron. 5 to 10 seconds and they pop right off.
But now to find out what the Hall sensor control driver IC’s are.
C840DI 1W100B5 - can not find any information on them.
