Mitch created LED support for new controllers like FOCstrot, LittleFOCer4 and Thor300- coming in Float Package v1.4
How to configure lights
Config options
- headlights brightness
- headlights brightness idle [MISSING NOW]
- headlights mode riding
- headlights mode idle
- status brightness
- status bar mode
Setup options
- led type: none, rgb, rgbw
- status count
- forward count
- rear count
Behavior
Someone please fill this in…
Wishlist
State awareness:
** Show light pattern when float package is disabled (e.g. 1-2 center red LEDs on each light bar)
** Show light pattern in handset mode (e.g. 1-2 center yellow LEDs on each light bar, still show footpad pattern when pressed)
** Go wild during flywheel mode
** Show error code on VESC fault
** Status bar blinking in tiltback situations? -
Allow adjusting of headlight idle brightness
Allow choosing headlight mode for riding, and headlight mode for idle
Power saver: after X Min of idle (e.g. 30min) turn lights off to save power, or switch to a single blinking LED instead
