This article serves as documentation to the suggested values used in Float Hub (VESC Setup App, more details coming soon) and other relevant behaviors throughout Setup.
If there’s any questions on how things behave or why things are the way they are, or feedback on things that you think should be changed or improved, please feel free to share in this thread. While the app is closed source, I want to stay as transparent as possible in how the app works behind the curtain so the community can verify and we can all be on the same page.
Also feel free to join the Float Hub Discord Server for more updates and discussion: Float Hub App
LAST UPDATED: 4/13/26 - v0.23.17
Controllers:
| Controller | Sample Rate (Hz) | Rated Max Current (A) | Max Input Voltage (V) | Default Motor | Default Battery | Default Tire Diameter (mm) |
| Floatwheel ADV | 800 | 180 | 96 | CannonCore V2 (ADV1) | Floatwheel ADV (20s2p LR2170LA) | 290 |
| Floatwheel ADV2 (Early Batch) | 832 | 225 | 96 | CannonCore V3 (ADV2) | Floatwheel ADV2 (20s2p 50S) | 290 |
| Floatwheel ADV2 (April '25+) | 832 | 270 | 96 | CannonCore V3 (ADV2) | Floatwheel ADV2 (20s2p 50S) | 290 |
| GTV Power Kit | 800 | 180 | 96 | Hypercore | GT (18s2p P42A) | 280 |
| XRV Power Kit | 800 | 180 | 96 | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| PintV Power Kit | 800 | 180 | 96 | Hypercore | Pint (15s2p VTC5D) | 265 |
| Thor300 / Thor301 | 832 | 300 | Firmware Max | SuperFlux Mk3 HS | Funwheel X7 (20s2p P28A) | 280 |
| Thor400 | 832 | 400 | Firmware Max | SuperFlux Mk3 HT | 30s1p P45B | 280 |
| Cheap FOCer v3 | 832 | 150 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Little FOCer v3 | 800 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Little FOCer v3.1 | 832 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Little FOCer v4 | 832 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Tronic 250R | 832 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Tronic X12 (24S) | 832 | 650 | Firmware Max | SuperFlux Mk3 HS | ‘777’ VOW GT (24s2p P45B) | 280 |
| Tronic X12 (30S) | 832 | 350 | Firmware Max | SuperFlux Mk3 HT | 30s1p P45B | 280 |
| Ubox 85 | 800 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| Ubox 100 | 800 | 150 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
| JetFleet F6 (32S) | 832 | 225 | Firmware Max | SuperFlux Mk3 HT | 30s1p P45B | 280 |
| JetFleet F6 (24S) | 832 | 270 | Firmware Max | SuperFlux Mk3 HT | ‘777’ VOW GT (24s2p P45B) | 280 |
| JetFleet F6 (20S) | 832 | 300 | Firmware Max | SuperFlux Mk3 HS | 20s2p P28A | 280 |
| Ennoid MK8 (30S) | 800 | 210 | Firmware Max | SuperFlux Mk3 HT | 30s1p P45B | 280 |
| Ennoid MK8 (28S) | 800 | 240 | Firmware Max | Hypercore v2 | GT S-Series | 280 |
| Ennoid MK8 (24S) | 800 | 270 | Firmware Max | SuperFlux Mk3 HT | ‘777’ VOW GT (24s2p P45B) | 280 |
| Ennoid MK8 (20S) | 800 | 300 | Firmware Max | SuperFlux Mk3 HS | 20s2p Battery Kit | 280 |
| Ennoid MK8 Pro (30S) | 800 | 400 | Firmware Max | SuperFlux Mk3 HT | 30s1p P45B | 280 |
| Ennoid MK8 Pro (24S) | 800 | 500 | Firmware Max | SuperFlux Mk3 HT | ‘777’ VOW GT (24s2p P45B) | 280 |
| Raiden 7 | 800 | 250 | Firmware Max | Hypercore | XR / PintX (15s2p VTC6) | 280 |
Motors:
The expected FOC Values are used for warnings in FOC Detection and follow this format: Min / Max / Margin. If beyond the Min / Max but only by less than the Margin, a yellow Caution will be displayed. If beyond the Min / Max by greater than the Margin, a red Caution will be displayed.
NOTE: The following Motors have limited publicized FOC Detection results, and thus have wider than typical expected value ranges. More data should be gathered on these for more accurate warnings:
- Hypercore v2
- Superflux Mk3 HT
- CannonCore V3
| Motor | Current Max (A) | Poles | Resistance | Inductance | Inductance Diff | Flux Linkage |
| Hypercore | 120 | 30 | 80 / 105 / 5 | 190 / 230 / 30 | 25 / 55 / 45 | 26 / 30 / 1.5 |
| Hypercore v2 (S-Series / XRC) | 120 | 30 | 65 / 85 / 15 | 140 / 200 / 20 | 25 / 55 / 45 | 26 / 30 / 1.5 |
| Sidewinder | 160 | 30 | 45 / 60 / 5 | 100 / 135 / 10 | - | 27 / 29 / 1.5 |
| SuperFlux Mk1 | 160 | 30 | 27 / 35 / 5 | 105 / 126 / 10 | - | 23 / 25 / 1.5 |
| SuperFlux Mk2 HS | 160 | 30 | 33 / 43 / 5 | 120 / 144 / 10 | - | 24.5 / 26.5 / 1.5 |
| SuperFlux Mk2 HT | 160 | 30 | 45 / 59 / 5 | 175 / 210 / 10 | - | 28.5 / 30.5 / 1.5 |
| SuperFlux Mk3 HS | 160 | 30 | 33 / 40 / 5 | 105 / 125 / 10 | - | 23 / 25 / 1.5 |
| SuperFlux Mk3 HT | 160 | 30 | 45 / 60 / 20 | 160 / 210 / 10 | - | 28 / 30.5 / 1.5 |
| SuperFlux 5" HS | 140 | 30 | 40 / 60 / 5 | 110 / 140 / 10 | - | 23 / 25 / 1.5 |
| SuperFlux 5" HT | 140 | 30 | 65 / 85 / 5 | 160 / 200 / 10 | - | 29 / 31 / 1.5 |
| CannonCore V1 (1st Batch) | 160 | 30 | 90 / 117 / 10 | 190 / 228 / 10 | - | 36 / 38 / 2 |
| CannonCore V2 (ADV1) | 160 | 30 | 65 / 85 / 10 | 130 / 156 / 10 | - | 29 / 31 / 2.5 |
| CannonCore V3 (ADV2) | 180 | 30 | 55 / 75 / 10 | 75 / 105 / 10 | - | 24.5 / 27 / 2 |
Batteries:
| Category | Battery | Cell Type | Config |
| Floatwheel | Floatwheel ADV | LR2170LA / DG40 | 20s2p |
| Floatwheel | Floatwheel ADV Pro | Molicel P42A | 20s2p |
| Floatwheel | Floatwheel ADV2 | Samsung 50S | 20s2p |
| Fungineers | Funwheel X7 | Molicel P28A | 20s2p |
| Stock | GT S-Series | Molicel P45B | 27s1p |
| Stock | GT | Molicel P42A | 18s2p |
| Stock | XR Classic | Molicel P30B | 18s2p |
| Stock | XR / PintX | Murata VTC6 / Samsung 30Q | 15s2p |
| Stock | Pint | Murata VTC5D | 15s1p |
| IndySpeedControl | 32s1p | Molicel P45B | 32s1p |
| IndySpeedControl | 30s1p | Molicel P45B | 30s1p |
| IndySpeedControl | 20s2p GT Pack | Molicel P45B | 20s2p |
| IndySpeedControl | 20s2p XR Split Pack | Molicel P45B | 20s2p |
| IndySpeedControl | 20s2p Battery Kit | Molicel P30B | 20s2p |
| IndySpeedControl | XRV PnP Kit | Molicel P45B | 18s2p |
| IndySpeedControl | 18s2p | Molicel P45B | 18s2p |
| IndySpeedControl | Smart Link 32s2p | Reliance RS50 | 32s2p |
| IndySpeedControl | Smart Link 30s2p | Reliance RS50 | 30s2p |
| The Board Garage | FAS Pack | Molicel P50B | 30s1p |
| The Board Garage | ‘777’ VOW GT | Molicel P45B | 24s2p |
| The Board Garage | GT ME4T Pack | Samsung 50S | 20s2p |
| The Board Garage | Extra Regular Pack | Molicel P30B | 20s2p |
| The Board Garage | Regular Pack | Molicel P28A | 20s2p |
| The Board Garage | 19s2p | Molicel P45B | 19s2p |
| The Board Garage | XR ME4T Pack | Samsung 50S | 18s2p |
| The Board Garage | Power Pack | Molicel P45B | 18s2p |
| Z Battery Solutions | Speed Pack | Molicel P28A | 20s2p |
| Z Battery Solutions | Torque Pack [P42A] | Molicel P42A | 18s2p |
| Z Battery Solutions | Torque Pack [P45B] | Molicel P45B | 18s2p |
| ChiBatterySystems | CBCSO | Murata VTC6 / Samsung 30Q | 20s2p |
| ChiBatterySystems | CBXR - Original | Molicel M35A / Sanyo 18650GA | 15s3p |
| ChiBatterySystems | CBXR - VESC Power | Molicel P28A | 15s3p |
| ChiBatterySystems | CBXR Mini | Sanyo 20700B | 15s2p |
| ChiBatterySystems | CBSP | Molicel P42A | 15s1p |
| ChiBatterySystems | Quart - Standard | Molicel P42A | 15s1p |
| ChiBatterySystems | Quart - S Edition | Samsung 50S | 15s1p |
Cell Types:
NOTE: Discharge Max is also used to calculate defaults for Charge Max and Field Weakening Current Max, as explained later in the documentation below.
| Cell | Discharge Max (A) | Capacity (Ah) |
| Samsung 50S | 35 | 5.0 |
| Molicel P42A | 40 | 4.2 |
| Molicel P45B | 45 | 4.5 |
| Molicel P50B | 50 | 5.0 |
| Reliance RS50 | 60 | 5.0 |
| Ampace JP40 | 60 | 4.0 |
| EVE 40PL | 60 | 4.0 |
| EVE 50PL | 60 | 5.0 |
| LR2170LA / DG40 (ADV1) | 40 | 4.0 |
| Molicel P28A | 30 | 2.8 |
| Molicel P30B | 35 | 3.0 |
| Molicel M35A / Sanyo 18650GA | 10 | 3.5 |
| Murata VTC6 / Samsung 30Q | 15 | 3.0 |
| Murata VTC5D | 25 | 2.8 |
| Sanyo 20700B | 20 | 4.0 |
- SETUP SCREENS -
Motor Setup:
- Motor Current Max / Regen Max tries to default to the Current Max in the Motor table above, with the Absolute Max Current 150% of this value (for safety headroom for current overshoot). If this would set Abs Max higher than the Controller’s configured Rated Max Current, Absolute Max Current is instead set to Rated Max Current, and Motor Current / Regen Maxes are brought down such that this is new Abs Max is 150% of their value (Motor Current Max = Abs Max / 1.5).
- If unchanged manually, Absolute Max Current will remain 150% of Motor Current Max or Regen Current Max (whichever is greater), up to the Controller’s Rated Current Max where it caps out (can still be raised beyond manually).
- A warning (red borders) will display on Motor / Regen Current Max anytime they are within less than 50% margin of Absolute Max Current.
- If Motor Current Max and Regen Current Max are equal and you manually tweak Motor Current Max, Regen Current Max will change as well to match unless changed manually. (This currently only works with + / - buttons, not text field entry).
Battery Setup:
- Discharge Current Max Default = Cell’s Discharge Max * P-Count (Capped at 90A currently, based on the limits of most existing controllers and wiring/connector configurations)
- Charge Current Max = -Cell’s Discharge Max * P-Count, or capped at either -35A for 1p, -45A for 2p, or -20A * P-Count for 3p+.
- This is a pretty rudimentary approach, but acts as a balance between some of the different viewpoints on battery current maxes in the community. Would like to flesh out a better approach, community feedback would be appreciated here.
- If P-Count is changed, Current Maxes are updated to the new defaults, even if they were manually tweaked prior
- S-Count is used along with the Voltage Cutoffs to calculate the Voltage Cutoff saved to the Motor Config (Cell Voltage Cutoff * S-Count)
- Voltage Cutoff Defaults:
- Cutoff Start: 2.7V / Cell
- Cutoff End: 2.5V / Cell
Configure FOC Parameters:
- Recommended/Optional Tweaks:
- Half Observer Gain: If Observer Gain is detected as above or equal to 1.0, default to setting Observer Gain to half of the detected value.
- Hypercore Crunch Fix: If Hypercore is selected, default to Resistance of 100, Inductance of 190, and matching Current KP/KI. Additionally, sets default Observer Type to Ortega Original and disable Saturation Compensation. These values aim to minimize motor crunch on hard accel/braking, but without the loss of power that we see when using Saturation Compensation.
- Lowered Time Constant: Lowers time constant from 1000µs to 400µs, which may improve motor response and reduce the risk of current overshoot (which can damage the controller). Note that this may result in a louder and less smooth feeling motor, especially at low speed.
- Current KP Default = Inductance / 1000
- Current KI Default = Resistance
Misc Parameters:
Temperature Cutoff Defaults:
- Controller Cutoff Start: 70°C
- Controller Cutoff End: 80°C
- Motor Cutoff Start: 80°C
- Motor Cutoff End: 90°C
Field Weakening Defaults:
- Duty Start: 65%
- Ramp Time: 500ms
- Current Max default is currently set in intervals, based on total Discharge Max across all cell series (Discharge Max * P-Count). Open to feedback on this:
if (dischargeMax >= 80) {
return 45
} else if (dischargeMax >= 60) {
return 40
} else if (dischargeMax >= 40) {
return 35
} else if (dischargeMax >= 30) {
return 30
} else {
return dischargeMax
if (sCount >= 30) {
return 0
if (sCount >= 24) {
if (dischargeMax >= 60) return 20
if (dischargeMax >= 45) return 15
if (dischargeMax >= 30) return 10
return 0
// Default logic for batteries less than 24s
if (dischargeMax >= 80) return 45
if (dischargeMax >= 60) return 40
if (dischargeMax >= 40) return 35
if (dischargeMax >= 30) return 30
else return dischargeMax;
Hall Sensor Defaults:
- Hall Interpolation ERPM: 250 ERPM
- Sensorless ERPM: 2000 ERPM
Observer Defaults:
- Hypercore (If Hypercore Crunch Fix is Enabled):
- Observer Type: Ortega Original
- Saturation Compensation: Disabled
- CannonCore V3:
- Observer Type: MXLemming Lambda Comp
- Otherwise:
- Observer Type: Ortega Lambda Comp
- Saturation Compensation: Lambda
Advanced Defaults:
- Zero Vector Frequency: 28.0 kHz
- ADV2: 25.0 kHz
- Fault Stop Time: 50ms
- Calibrate on Boot: Off
- OTHER BEHAVIORS -
At the conclusion of Setup, the following values are also written to the Motor CFG behind the scenes:
- Sensored ERPM Start (6.05+ Only): 0.9 * Sensorless ERPM
- Gear Ratio: 1.0
- Acceleration Temp Decrease: 0%
- Temperature Compensation: Enabled
- Field Weakening Q Current Factor: 2.0%
- BMS Limit Modes: All Disabled
- Speed Tracker Position Source:
- FW 6.05+: Corrected Position
- Otherwise: Observer
- Maximum Input Voltage:
- Floatwheel Controllers (ADV’s / Power Kits): 96V
- Otherwise: 200V (truncated to firmware’s defined hardware limit)
- Minimum Input Voltage: 18V
- [Thor400, and Tronic X12 ONLY]** Current Sample Mode:** All Sensors Combined
- JETFLEET EXCEPTIONS -
Per recommendation of @FajdigaESC, various defaults have been changed when selecting a Jetfleet controller:
- Recommended Tweaks:
- Half Observer Gain and Hypercore Crunch Fix are DISABLED
- Lowered Time Constant (400µs) is ENABLED
- Current Sample Mode:
- FW 6.05: All Sensors Combined
- FW 6.06+: Longest Zero Time
- Short Fets on Zero Duty: Enabled
- Sensorless ERPM: 2500 ERPM
- Sensored ERPM Start: 0.8 * Sensorless ERPM [2000 ERPM]
- Zero Vector Frequency: 30 kHz
