Hello,
So I just started to feel comfortable and like my Mad Mad VESC when FAULT_CODE_HIGH_OFFSET_CURRENT_SENSOR_1 happened. I took t he motor apart, changed the HALL sensors but with the same result.
The VESC is a Flipsky Mini FSESC4.2, the motor is an electric scooter “Citycoco” motor and the battery pack is a 13s diy…
I tried a skateboard motor with the same result.
I’m at a loss on how to continue. I don’t have another way to test the motor to make sure it still works.
Can it be a software issue?
Thank you,
Dan
