Drop Kits for VESC Conversion
This guide provides information about drop kits that allow you to convert a stock Onewheel to VESC without any soldering.
Understanding Drop Kits
Drop kits are designed to simplify the process of converting a stock Onewheel to VESC by providing pre-wired components and connectors that eliminate the need for soldering. This makes VESC conversion more accessible to riders who may not have soldering experience or prefer a plug-and-play solution.
Available Drop Kits
Available Options:
  • AvaSpark: AvaSpark offers VESC conversion kits for various Onewheel models, including the Pint and GT. These kits aim to simplify the conversion process and are popular among users who are new to DIY Onewheel modifications. It’s important to note that even with these kits, you may still need to perform some basic wiring or modifications, such as bridging the positive on the BMS, which might require minimal soldering.
  • XRV, GTV & PintV (by Floatwheel): Controllers and BMS specifically designed to fit stock Onewheel enclosures. No soldering required. You swap out controller and BMS.
  • Fungineers GTFO Kit: Replacement Kit to swap out the GT Parts with Thor300, Fungineers BMS, Superflux Motor and improved LED lights
Considerations for Choosing a Drop Kit
  • Compatibility: Ensure that the drop kit is compatible with your specific Onewheel model (e.g., Pint, XR, GT).
  • Components: Check the components included in the kit, such as the VESC controller, BMS, wiring harness, and any additional accessories.
  • Ease of Installation: Look for kits that offer clear installation instructions and require minimal modifications to the stock Onewheel components.
Benefits of Using a Drop Kit
  • Simplified Installation: Eliminating the need for soldering makes the installation process faster and more accessible for beginners.
  • Plug-and-Play Convenience: Pre-wired components and connectors ensure compatibility and reduce the risk of wiring errors.
  • Time Savings: Drop kits can save significant time compared to sourcing individual components and creating custom wiring harnesses.
Additional Information
  • Availability: The availability of specific drop kits may vary depending on the manufacturer and retailer.
  • Cost: Drop kits typically cost more than purchasing individual components separately. However, the convenience and ease of installation may justify the higher price for some riders.
  • Customisation: Drop kits may offer limited options for customisation compared to building a VESC setup from scratch. If you’re looking for maximum flexibility, consider sourcing individual components and learning the basics of VESC wiring.
