Diagnosing hall sensors
vesc tool includes functionality to diagnose hall sensor issues, it’s best to do this using the Desktop tool.
  1. Go to the Terminal window and type “hall_analyze 10” and hit enter
    This will produce a written report, if it says your sensors are good or mostly good then you’re done.
Here’s an example result reporting “significantly misaligned” hall sensors, which warrants investigation in step (2):
  1. Looking at the graph
    If the test above returns a bad report (e.g. “significantly misaligned”), you can view the graph in “Data Analysis”, “Realtime Data” using the “Experiments” tab. Here you will see a graph with the 3 hall sensors and the combined state. From that graph you can conclude which hall sensors behave correctly (switching between on and off states) and which ones don’t. You will see 3 colors, one each for H1, H2, and H3 - representing the 3 hall sensors. Any color that flatlines indicates a broken hall sensor (or broken hall sensor wire). Most “bad” hall sensors are usually bad connectors or bad wiring.
Example:
The graph below shows Hall 1 in blue toggling, as well as Hall 2 in red toggling, but Hall 3 (purple) isn’t visible because it’s always 0. Therefore Hall 3 is the one that needs to be investigated
thanks this was simple to help me confirm the issue with my floatwheel as you can see with the results below
My problem is VESC Tool crashes (desktop macminipro M2)when trying to connect. I’m trying to diagnose a XRV (what I believe is hall sensor problem). I’ve calibrated more than a few boards using VESC Tool desktop but this one, just crashes the program. I’ve done all the normal reinstall stuff, and I’m sort of stuck.
Are you connecting via TCP Bridge? On Desktop VESC Tool you can’t use direct Bluetooth connction, see:
How to connect VESC Tool Desktop App via Bluetooth (PC/Mac)
