How to enable Darkride:
Requirements:
- requires my ATR firmware or a recent float package
- also requires positive speeds in the RT data screen or FloatControl when riding forward - otherwise dark-ghosting is virtually guaranteed!!
How to enable:
In Faults: Set roll fault to 180 degrees
How it use it:
- You have to ride normal first, then you can flip the board over and darkride.
- Darkride doesn’t care about sensors, but it will stop when riding in reverse.
- After 10s or longer without engaging the board darkride is disabled, you have to ride it normal again to re-enable.
