When setting up your charge only bms what voltages are recommended?
Specifically for me I’m using a ennoid bms and was curious if people are changing the following settings or leaving them as the default:
soft over voltage, hard over voltage, balancing voltage start
I’ve had to raise mine to allow for a full charge. I don’t recall the exact values I used but hard over I think I’ve set to 4.25, soft to 4.2 or something similar.
My XLite likes to get really hot when balancing, so you may want to keep an eye on your temperatures as well
