Little focr board. On my last ride one of the foot pad sensors stopped working. I assumed the sensor itself died so when I arrived back I swapped a known good sensor in place… But the same issue is still there. ADC 1 always reads 1.5 volts no matter what. I tried unplugging the foot pad and turning the board back on, still 1.5 volts. Wiring all looks ok, nothing pinched, broken or rubbing. Anyone else has this issue or something similar? I’m starting to believe the controller is done.
I had the same issue with a lfocer once, not sure what caused it. i still have it on a shelf. Sorry that’s not much help
whats the issue? does it not go above 1.5V or something? the numbers are arbitrary. my focer 3.1 has since day one read ADC 1 as .86v at all times, and instead of 3.27v goes up to 2.10 when engaged. this is literally unnoticeable. set your adc to 1.6 and forget about it
This is a known issue. The little FOCer pins are flipped around for adc1, 3.3v, and adc2. You are connected to 3.3v rail instead of the 2nd sensor output
my issue was a broken ADC rail on the lfocer. ADC1 read ~1.5V with nothing plugged in. i used it for a while on a Bike build with ADC2 as current throttle and just omitted using ADC1. ![]()
