About the Hardware, Parts and Tools category
This category is intended to be used to post topics and links on recommended (or not recommended) hardware, parts and tools to be used for custom builds. It is intended to publish and upvote links to purchase hardware, parts and tools as well as basic information on popular/recommended products such as datasheets and technical specs.
For example you might post a link to where others can buy a device such as the latest FOC or ESC boards, links to helpful parts or vendors, or datasheets or other information on relevant hardware , parts and tools.
You should not use this category for posting topics about troubleshooting of a specific issue with a piece of hardware, part or tool. If you had a major problem with something it makes sense to leave a comment about the issue you had on that part here, but not post an entire topic about issues or troubleshooting of it. Details on specific issues, troubleshooting and solutions for specific issues should be posted in the Troubleshooting - General category.
Hello everyone. I need lot of help. First of all sorry ,English is not my born language and I am an amateur in terms of VESCs,etc. Some year ago I built myself a skate board with VESC 4,12( this was in 2018) using 2 X3S batteries total 6s. I also used a Turnigy 245v motor. Ran ok for a while. Than I built another battery bank with 40 x 18650 batteries( 10S total) it was perfect. After some time stopped i make it happens again, now with 2 x 6S batteries, total 12 S and 8 amps. I updated firmare using an updated VESC tool and set the parameters. The acceleration curve is not good and it has some failures, like some cuts. I was checking the Motor spec and it seems that cannot support 12S but maximum 10S. I am not sure about the Vesc hardware capacity. Can anyone help to understand and maybe make the right configuration for this combination??? Thank YOU
