Did you possibly change the Motor Current Max values instead of the Battery Current Max values?
As an FYI, you’ll also need to restore configs after installing a different package (in case you didn’t).
If you find that you’re unable to get the board operational and want to start fresh, you can either follow the guide below, or use the Float Hub app to make things even easier.
