Surfdado Firmware Buzzer
What is the buzzer?
A small device that beeps when stuff happens
How do I get one?
Any device that emits noise (or light if you prefer that) when 3.3V is applied and is silent when 0V is applied can be used. The one I like is a Grove Active Buzzer:
Seeed-studio
How to hook it up?
I'm using the servo pin for this purpose. So the servo pin controls the beep, while GND/5V power the beeper. It is also possible to power it straight from the servo pin but some buzzers may not be loud enough at 3.3V.
What firmware do I need?
The buzzer only works on surfdado firmware. Why not on standard firmware? Because Mitch no likey :)
Also: to enable it: in App-General set Enable Servo to TRUE
What's the behavior?
Here's the list of situation when it beeps:
  • Constant beep when foot sensor fault detected at speed
  • Duty tiltback angle set to 0? It will beep instead
  • Triple-beep when high voltage tiltback triggered, triple-beep on low-voltage
  • On boot: short beep when VESC boots, long beep when balance app is ready (and each time you write app config!)
  • Beeping when 2-3 degrees away from overtemperature throttling
  • LV beeps on boot: Are we less than 5V above LV tiltback threshold? Issue 1 beep for each volt below
    that level.
  • Attempting to write config while riding? 3 long beeps tell you “nope”
