ATR Firmware 101
interesting - I added a feature to warn me if I accidentally left an erpm limit in place that’s too low, you must have an erpm limit of 10,000 or less. This is dangerous, increase it
Thanks. It was set right at 10,000. What is a safe value to have it at? I have a stock FM XR battery and hub.
I now have it set at 12,000 and it starts up great. I am glad that you put the beeps in there. I didn’t know that it was set too low. Thanks.
2k is about 4mph, so 10k is equivalent to 20mph, 12k is 24mph - even that limit can be dangerous because with a stock battery you could reach 24mph on a full charge and if you’re daring enough, the last thing you want is to limit your speed by causing nosedives - I’d set this limit to at least 15k
use tiltback settings to limit your speed
Thanks for the help. I have adjusted the value tp 15000.
Hey surf, the “100_250” fw is compatible with the ubox 100A/100V units, correct? Mine is reporting HW ID as UBOX_SINGLE_100. Thanks.
I don’t understand the question. I know nothing about 100_250 - there’s a Ubox Single 100 firmware if you have a UBox100
Ah ok, google drive just wasn’t showing all of the binaries in the zip! Sorry!
